Portforwarding HMI
Hello guys,
We use the AXC F 2152 in combination with a 3G/4G router.
We use portforwarding to reach the HMI, but with the AXC F 2152 we've problems to reach the HMI through portforwarding.
The forwarding connects to port 443 of the PLC.
I get to see the HMI background, but there are problems to load the variables. I see then the errormessage: A connection with the PLC could not be established. Retrying in X seconds
It seems that the API connection can't be established:
hmiapp.min.js:133 [Tue Feb 04 2020 10:46:36 GMT+0100 (Midden-Europese standaardtijd)] ERROR: Base Data Access service's XML HTTP Request failed for command 'ReadGroup' with status code '0' and status text ''.
hmiapp.min.js:133 GET https://xxx/_pxc_api/v1.1/groups/g198577/?sessionID=s1176754085& net::ERR_CERT_AUTHORITY_INVALID
hmiapp.min.js:133 [Tue Feb 04 2020 10:46:36 GMT+0100 (Midden-Europese standaardtijd)] ERROR: Data client's Update Data failed due to status '2', but retry limit (1) already reached.
How can this be solved?
Kind regards,
Robin
  • Hi Robin,
    This problem has been reproduced by the developers and the root cause has been identified. Unfortunately we do not have a workaround at this stage but we are hoping that the problem will be fixed with firmware version 2020.3 (latest end of April).
    ~ Martin.
