COULD NOT CONNECT TO THE CONTROLLER
After reseting the controller to factory default. I can not connect to my controller anymore.
I have done the reset option 1 and 2.
BF-C blinking 1hz
BF-D blinking 1hz
D permanently orange
RUN is green
Connection with PUTTY is possible. but not with PlcNext Engineer.(going online is not possible)
Can you help me please.
Thanks
Yalcin
I am having the exact same issue. Same LED configuration as described.
This post seems to have some relevant info. I just found out mine is not set up with the same firmware as the sample project.
https://www.plcnext-community.net/en/discussions-2-offcanvas/problem-to-connect-to-the-controller.html
