We need some system variables of AXC F 2152
Hello Sir,
We need some system variables of AXC F 2152.
for example:
PLCMODE_RUN,
PLCMODE_ON,
PLCMODE_STOP...
We have customers who need to do status testing, none of which.
How can we solve this problem?
Thanks!
  • Hello,
    The PLC state is available from the IPlcManagerService2 RSC service - which is accessible from PLCnext components written in C++.
    Where would you like to see this information?
    ~ Martin.
  • Hello Sir,
    We are clear about this, but the customer thinks it is too troublesome. They need to call it directly in plcnext engineer.
  • OK. I am not sure what your customer wants. Where exactly does the customer want to see this information? In PLCnext Engineer? On a HMI screen? In an OPC UA client? Somewhere else?
    ~ Martin.
  • Hello Sir,
    They need the system variables to trigger the corresponding function block initialization, and also need to be displayed on the SCADA.
  • Thanks for clarifying.
    You might be able to achieve this using one or more Event Tasks in PLCnext Engineer:
    2020 02 19 9 51 02
    For exampe, you can use the "Stop" event to trigger a task that executes a program that sets a variable indicating the PLC state. If this variable is marked with the "OPC" attribute, then the value of this variable can be displayed on a SCADA system via the corresponding OPC UA tag.
    ~ Martin.
  • Hello Sir,
    We will inform the customer after the test and persuade the customer to adopt other methods.
    Thank you very much !
