eHMI with User Authentication by a Windows Active Directory server?
I have the following requirements:
- Simple HMI for a machine ( ✓ AXC F 2152 with eHMI)
- HMI users need to log in ( ✓ AXC F 2152 with eHMI)
- HMI users must be authenticated against a Windows Active Directory server. ( ??? )
Can a PLCnext guru tell me if this final requirement is currently possible and if not (which I suspect) - are there any plans to make this possible, or else any tips on how I can easily roll my own AD authentication with eHMI?
  • > - HMI users need to log in ( ✓ AXC F 2152 with eHMI)
    Currently with AXC F 2152 (firmware 1.0.0.250) the eHMI user can not (needs not) log in. In 2018 we want to bind eHMI to the PLCnext User Manager.
    In the future we intend to combine the PLCnext User Manager with LDAP. This would also enable a combination with Active Directory Server.
  • Hi Martin,
    If you are feeling really adventurous, you might (but it again... you probably shouldn't), cross-compile your own nginx-binary, and combine it with this module https://github.com/kvspb/nginx-auth-ldap. and swap it with the on-target binary.
    This would enable you to have ldap-auth from within nging's config files, where you place certain URI's behind ldap auth.
    You should at least compile with the current options:
    root@axcf2152:~# nginx -V
    nginx version: nginx/1.10.1
    built with OpenSSL 1.0.2j 26 Sep 2016
    TLS SNI support enabled
    configure arguments: --crossbuild=Linux:arm --with-endian=big --with-int=4 --with-long=4 --with-long-long=8 --with-ptr-size=4
    --with-sig-atomic-t=4 --with-size-t=4 --with-off-t=4 --with-time-t=4 --with-sys-nerr=132
    --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log
    --error-log-path=/var/log/nginx/error.log --pid-path=/run/nginx/nginx.pid
    --prefix=/usr --with-http_ssl_module --with-http_gzip_static_module
    But i highly advice against it, as it might break more than you bargained for.
