Eclipse not recognizing that AXCF2152 is connected
I am following the tutorial for programming with c++ on eclipse. While setting up a project, you are supposed to select the AXCF2152 as a target for the program. However, when I do this, there Is nothing on the available targets list.  Are there other steps I need to take?
  • Hello,
    Have you installed the C++ development tools, on Windows or Linux?
    If so, what is the result of the the following command-line commands:
    plcncli get targets
    and
    plcncli get sdks
    You should see the PLCnext target(s) that you have installed on your host system. These same targets should appear in Eclipse.
  • Hello,
    if you have installed the PLCnext CLI and added the plugin for Eclipse, you can see and manage your SDKs via Eclipse Window-->Preferences as you can see in the screenshot.
    CLI Eclipse SDK Settings
