Gateway configuration not transferred to controller?
edited March 2020 in PLCnext Engineer
PLCNext Engineer 2020.0 (Build 4.0.250.0)
Controller: AXC F 2152, FW 2020.0 LTS (20.0.0.24752):
I've configured a static IP address: 10.2.3.213 / 255.255.255.0 / 10.2.3.1 but couldn't reach PROFICLOUD or any other external IP address. I logged on to the controller via ssh to check the /etc/network/interfaces file. The device address and mask were correct but the gateway address said 0.0.0.0 and had obviously not been transferred from PLCNext to the controller. After I corrected the interfaces file manually and restarted the system everything worked as expected. Funny thing?
Regards, Wolfram
  • Hi Wolfram,
    I create several new PLCnext Engineer v 2020.0 projects every week, all with a non-default Gateway address, and I have never had this problem, but that's not to say that it's not possible.
    Can you please confirm that this is reproducible behaviour, if so then I will pass this to the PLCnext Engineer team, and they will let you know what additional information they need from you to investigate further.
    ~ Martin.
  • Yes, it seems to be a reproducible behaviour.
    I just configured a new gateway address like this
    address 10.2.3.213
    subnetmask 255.255.255.0
    gateway 10.2.3.2
    and uploaded it to the controller.
    Logged on with SSH and using ip r I've got this:
    root@axcf2152:/opt/plcnext/# ip r
    default via 10.2.3.1 dev eth0
    10.2.3.0/24 dev eth0 scope link src 10.2.3.213
    The gateway address did not change from 10.2.3.1 to 10.2.3.2. Where am I wrong?
    Regards, Wolfram
  • Hi Wolfram,
    OK, I have reproduced what you are seeing, and this was my misunderstanding.
    Using PLCnext Engineer, it is only possible to change the IP parameters of the PLC using the Project -> Online Devices window:
     2020 03 10 13 10 58
    This is way I have been setting the Default Gateway in my projects, so I misunderstood the problem (sorry!).
    It is not currently possible to change the default gateway by downloading a new PLCnext Engineer project to the PLC. From PLCnext Engineer, this can only be done from the Online Devices window.
    ~ Martin.
  • Thank you Martin - I got it!
    I assumed new IP settings are transferred with an upload as it is the case with Siemens PLCs, for example.
  • Yeah, this isn't clear in PLCnext Engineer. Hopefully this will improve in a future version.
    ~ Martin.
