Communication between PLC and Computer ?
Hi everyone,
Currently I have a computer application (in C #) which communicates with PLCs via modbus ... but modbus is starting to be too slow for our application.
I thought maybe be able to use PLCnext controls to manage the exchanges with the computer, is that possible?
I see that it is possible to integrate C # and then send it to the controller, but would this solution allow communication with software on a computer itself also programmed in C #?
I just discovered PLCnext so I am trying to understand if this solution can answer my problem, and replace Modbus with a faster solution to communicate with my application on my computer.
Thank you!
  • Hello raphy,
    Yes, this is possible.
    No, unfortunately the C# programming feature on the controller does not make it any easier to communicate with the PLC from an external C# application.
    Custom-built applications running on a PC currently have a number of options for communicating with the controller, including:
    • Fieldbus protocols like Profinet, Modbus or Ethernet/IP.
    • OPC UA (the PC would need to implement an OPC UA client).
    • REST API calls (the PC would need to implement a REST client).
    • Java API (for PC applications written in Java)
    • MQTT
    • Your own custom-written service running on the PLC, e.g. in a Docker container, that somehow transfers data to the PC.
    The solution you choose will depend on a number of factors, including the required data transfer rate.
    Hope this helps.
    ~ Martin.
  • Thank you very much Martin,
    Your answer is really complete, I understand the solution better now.
    Thank you.
