Ask for Installation of PLCnext Engineer
Hello Colleagues,
I got question for Installation of PLCnext Engineer to PC.
Execute the installer, but the installation does not complete.
The progress bar stops at about 30%, and there is no change even after 1 hour.
So, looking at the task manager, the operating rate of the hard disk is 100%.
What are the possibilities?
Software: PLCnext_Engineer_Setup_2020.0.1_LTS_(64bit)
PC: Panasonic CF-LX6BDAQR
Processor: Intel Core i5-7200U 2.5GHz 2.7GHz、RAM 8GB
OS: Windows10 Pro 64bit 1909
Other Development Software : OMRON CX-One V4 .40.0005, Mitsubishi GX Works2 1.570U/GX Works3 1.058L, Microsoft Microsoft Visual Studio Code 1.39.1,
Best Regards,
Please check that the PLCnext Engineer installer downloaded successfully, by checking the file size (as a rough guide) or by using
CertUtil
(to be sure) against the information on the download page.~ Martin.
Hello Martin-san,
Thank-you for your answer,
I got information about installer and progress dialog, and try to get information of CertUtil later
(Unfortunately, I can't access download page of product... )
Best Regards,
Ah, OK.
The SHA256 Checksum (for checking with CertUtil) is:
0f656daa0a19023070db58cb6f9e13b75cbebe3b5f4c529f269fcc31c2696ec8
The file size is listed as 467 MB, so that is there or thereabouts, based on your screenshot.
So an incomplete download is unlikely to be the problem. I will discuss this internally and come back with a suggestion.
~ Martin.
additional information
Hash is OK, and situation didn't change after re-downloading and re-installing
attached file is hash information,
Best Regards,
Problem solved via email.
