PLCnext Engineer couldn't open as normal
Hello Sir
PLCnext Engineer software always couldn't be open as normal, could you help me ?and the report list is as follow:
PLCnext Engineer, Version 2020.0.1 (Build 4.0.266.0)
Unexpected Exception
The composition produced a single composition error. The root cause is provided below. Review the CompositionException.Errors property for more detailed information.
1) Object reference not set to an instance of an object.
Resulting in: One or more errors occurred.
Resulting in: An exception occurred while calling the 'OnImportsSatisfied' method on type 'Ade.ApplicationControl.ApplicationControlServerComponent'.
Resulting in: Cannot activate part 'Ade.ApplicationControl.ApplicationControlServerComponent'.
Element: Ade.ApplicationControl.ApplicationControlServerComponent --> Ade.ApplicationControl.ApplicationControlServerComponent --> AssemblyCatalog (Assembly="Ade.ApplicationControl.ContractsImpl, Version=4.0.266.0, Culture=neutral, PublicKeyToken=55558f70c9068f5b")
Resulting in: Cannot get export 'Ade.ApplicationControl.ApplicationControlServerComponent (ContractName="Ade.Components.IStartupModule")' from part 'Ade.ApplicationControl.ApplicationControlServerComponent'.
Element: Ade.ApplicationControl.ApplicationControlServerComponent (ContractName="Ade.Components.IStartupModule") --> Ade.ApplicationControl.ApplicationControlServerComponent --> AssemblyCatalog (Assembly="Ade.ApplicationControl.ContractsImpl, Version=4.0.266.0, Culture=neutral, PublicKeyToken=55558f70c9068f5b")
Exception chain:
Details
Message:
Stack trace:
at System.ComponentModel.Composition.Hosting.CompositionServices.GetExportedValueFromComposedPart(ImportEngine engine, ComposablePart part, ExportDefinition definition)
at System.ComponentModel.Composition.Hosting.CatalogExportProvider.GetExportedValue(CatalogPart part, ExportDefinition export, Boolean isSharedPart)
at System.ComponentModel.Composition.Primitives.Export.get_Value()
at System.ComponentModel.Composition.ExportServices.GetCastedExportedValue[T](Export export)
at System.Lazy`1.CreateValue()
at System.Lazy`1.LazyInitValue()
at Ade.Components.ComponentFramework.a()
at Ade.Diagnostics.ApplicationEventSource.<>c__DisplayClass8_0.b__0()
at Ade.Diagnostics.ApplicationEventSource.RunAction[T](String category, String actionName, Func`1 action)
at Ade.Diagnostics.ApplicationEventSource.RunAction(String category, String actionName, Action action)
at Ade.Components.ComponentFramework.Init()
at Ade.UIFramework.MainControl..ctor()
at (PCWorxNextApplicationStarter )
at PCWorxNext.PCWorxNextApplicationStarter.CreateMainWindow()
at Ade.Application.ApplicationStarter.Init()
at (String[] )
at PCWorxNext.Startup.Main(String[] args)
I would like to recommend you to uninstall the PLCnext Engineer 2020.0.1, install the last version 2020.3 and try to open your project again.
Please send me a short feedback, if the problem can be resolved or not.
Thanks & Best Regards
Eduard
Hello Sir ,unfortunately,even worse, I couldn't install 2020.3 PLCnext engineer at all. And the prompt message is very limited . So could you help me to anysls it?
I've spoken with the dev department.
It seems that this issue is quite often related to some user rights and or some virus scanners, they suggested me the following:
Keep also in mind that you need Windows 10 64Bit!
If this still not help please contact your local Phoenix Contact sales representative to get in direct contact with you.
Reg
Frank
Did you try everything on the list that Frank suggested?
If none of that works, then Frank's final suggestion is worth a try:
