ComSiemens library
I have a questions about ComSiemens library:
1) How many bytes is possibile to exchange between an AXC F 2152 and a S7-1500?
2) Is possibile to exchange LREAL data types?
3) How many S7-1500 could be read with one AXC F 2152?
My customer needs to read 200 LREAL from one or (if possible) more S7-1500 and needs to log this data every 5 s. I think is too fast, what dou you think?
Thanks in advance.
HI Alberto,
Here are the answers from the developer of that FB library:
1. The length of Bytes which can be transmitted in one telegram is communicated between S7-CPU and PxC-CPU. And the maximum length is shown at the Output "iMaxDataCount" at the Functionblock CoSi_ETH_S7_Link.
Reading all LREALS together is not possible 200 LREAL = 1600 BYTE --> Minimum 4 Read Jobs neccessary.
In my tests the length between 2152 and S7-1511 CPU is 452 BYTE.
2. Yes it is possible with the S7-12xx AND 15xx CPU. But there is no Functionblock available.
The customer can program an own functionblock.
The customer should use the CoSi_JobInterface for one LREAL Read process.
Offset, from which to be read/written from the Siemens PLC. The
counter/timer number is to be specified in the case of the counter/timer
data type, from which is to be read/written. In the case of all other data
types, the specification is in bytes.
With rising edge of xDone the read Data must copied out of the "CoSi_ETH_S7_Link.arrDataBuffer".
If you want to get seperate LREAL as output use BUF_TO_LREAL with connected arrDataBuffer and following parameters: REQ = Trigger from JobInterface.xDone; BUF_FORMAT = TRUE; BUF_OFFS = 0 for the first LREAL; BUF_CNT = 8 BYTE
The next LREAL starts at arrDataBuffer[8] ... and so on.
3. The count of Connections is limited to the maximum number of open Sockets of the PLCnext Engineer CPU.
I could not find any information about the exact count in the datasheets. But i heared about hundreds of possible Sockets.
