PLCNext Firmware updates issues
Hi to all!
First of all, congratulations by this beautiful piece of hardware and software.
I acquired on PLCNext on last week. By recommendation, I installed the software (PLCNext Engineer) and updated the PLCNext firmware to the latest version. The firmware update is the reason for this message.
The issue that I have found on this process, is that I have downloaded a ZIP file, that after extraction, gives me a Windows executable file. And after run this file, after some dialogs, they extracted three files, the job that can be done with a simple Zip file, removing one unnecessary step. The major problem that I see at the current state of the firmware update process, is that Linux users had to access a Windows machine (or install Wine) to extract the files from EXE file, to them, proceed with the firmware update, that can be done via browser.
This is a suggestion, to make the firmware update easiest and faster.
The best regards,
Fabio
Hello Fabio,
Thank you for your feedback and suggestion. I forwarded it to product management for evaluation.
I hope we can provide a more efficient way for FW container extraction.
Best Regards
Eduard
Hey Fabio,
it took a little while, but we did not forgot this topic ?.
With the newest release (FW 2021.0LTS) you'll find in the downloadcenter the FW packages as a .zip which contains the .rauc, change notes and user manual.
Take care,
Frank
