Debugging C# code via Visual Studio hangs while Attach to Process
After applying the instructions in the following video, it is not possible to perform debugging.
https://youtu.be/BLf6OZKEGLo
https://youtu.be/7LLY-_rGKMg
When you press Attach to Process, Visual Studio hangs. How can the problem be solved and debugging be done?
Versions:
PLC Next Engineer 2020.6.2, Firmware: 2020.6.1 (AXC F 2152)
Visual Studio 2017
