HART with PLCnext Control
I was trying to connect the I/O module - AXL F AI8 HART XC 1F - 1052434 to my AXC F 2152, but I can't find it in PLCnext Engineer.
Is this module supported with PLCnext or do I need to get a workaround with HART gateway?
BR
Jarkko
Hello Jarkko,
I send you the FDCML3 file for this module.
As this is a fairly new module it has not yet been included in the PLCnext Engineer.
It will however be added in the next version.
For now you can add it manually.
kind regards,
Hi Oliver,
if it is in the eShop it has to be implemented - no way around that.
We don't buy your products to use them as paper weights
Peter Paul
