C++ StaticString to String
Hi All!
I'm reworking a the costum notification sender to be more flexible in the future.
I'm trying to convert a StaticString<80> to a string type to fit in the "example payload" of the example provided in GitHub.
But I'm probably missing something as I can't succeed. Can someone give a hint?
I guess I can convert a byte array to a string as well, is this the preferred way?
Kind Regards
Dries
  • Hello Dries,
    please the following code:
    //Definition in Component or Program header file:
    pcoslib::IecString80 strValue;
    //Initionalisation in C++ code:
    this->strValue.SetCapacity(this->strValue._Capacity_);
    this->strValue.Remove(0);
    //Convert the IecString80 to string:
    string strNormValue((char*)strValue->Begin());
    I'dont test it, but it should work.
    Best Regards
    Eduard
