Fail Node-Red innstall in Docker
I would like to install Node-Red without memory card on PLCnext (AXC F 2152) FW 2020.6. For installation I have followed the following instructions.
https://github.com/PLCnext/Docker_GettingStarted
https://www.plcnext-community.net/en/hn-makers-blog/482-node-red-with-docker-tips-and-best-practice.html
https://www.plcnext-community.net/en/hn-makers-blog/481-node-red-and-getting-started-with-docker.html
With me there is always the error that the memory is full.
Did anyone manage to install Node-Red without a memory card and can anyone send me detailed instructions?
Many thanks in advance
Best Regards
robo7795
  • Hello robo7795,
    in order to use node-red with docker on th AXC you need an external SD card. The internal memory is too small for this installation and I cannot think of a way to make the installation small enough to fit.
  • Hello,
    Thank you very much for your information.
    Is a 2GB memory card sufficient for the full function of Nod-Red?
    Best Regards
  • Hello robo7795,
    a 2 GB card will probably work but I would recommend to use the 8 GB card to not run out of memory soon again.
    Best regards
    Stefan
  • Can  you show us the output from
    df -h
