IOL-CONF
IOL-CONF requires connected IO-Link devices version 1.1.1. But main manufactures have not such devices yet (for example https://www.ifm.com). So this software is a bit future investment or something else?
Thanks a lot.
Thanks a lot.
Hi Dzmitry,
Unfortunately this question is not related to PLCnext Technology, so you should raise this question through your local Phoenix Contact office.
However, the people from our IO support team here gave this answer:
Version 1.1.1 refers to the IO-Link specification. The current version is 1.1.2. and this version has been released for 5 years. Most IO-Link devices therefore have at least version 1.1.1.
Which device can you not use?
Hi Martin,
thanks for your quick response. For example this device - https://www.ifm.com/de/de/product/LDL200. It has IO-Link revision 1.1.
Here is the next reply from the IO Support team:
If you would like to follow this up with your local support contact, please quote reference number 203955.
Hi Martin,
thank you. We will test it again.
