Startup with the can module
Hi I'm new to the PLC world. I'm actually playing with the AXC F 2152 and the AXL F IF CAN 1H 2702668. I'm struggling to get any data from the FB.
The D and the 00 led are flashing green (see the attachement video).
  • I find out the meaning for the D led (The station is ready to operate, communication within the station is OK. The data is not valid. The controller or higher-level network is not providing valid data. A malfunction has not occurred on the module), but I don't know how to resolve this.
  • What's the signification of the 00 led flashing ?
    I also use the example from the can_9, I joined a screenshot of the module. I need to specify the clock frequency, the nominal bitrate and the data bitrate, where can I find those parameters ?
Anyone to solve my issue please ?
  • Hello rajee,
     please see the answer from my colleagues in charge of your request:
    • For solving the D-LED flashing behavior you have to set an output processdata in the localbus (AXL) for it
    • Please have a look to the attached screenshot
    • It depends from your CAN-Bus device. It has to be in the datasheet of the module for example
    Best Regards,
    Eduard
  • Problem solved, Don't really know what was the issue. I updated the firmware to the latest one and the support helped with the use of the function block.
