Opencv in python3 (container)
Good evening,
I have a project, in which I need to run the opencv on the AXC F 2152.
We are already running in a container (used in this tutorial https://www.plcnext-community.net/en/hn-makers-blog/556-containerized-opencv-python-on-plcnext.html) , it is opencv running on python2.
There is some container for this plc that has opencv in python3?
Or how to use, the same variables in PLCnextengineer and python2?
PS: I need in python 3 because I need communicate with PyPLCn.
PS2: I tried to install python-opcua to try to use python2 in communication, but I couldn't (apparently there is an error in the installation due to lack of ram).
Thanks,
Dino Silva
You can install python3 in the image. Simply create a new image with the image and a docker file. It is a debian jessi, so python3 would be version 3.4.x
For building a image you need Docker, Belena is not possible.
dockerfile:
For build:
Out of interest, why is it not possible to build an image using Balena?
In this tutorial:
https://www.plcnext-community.net/en/hn-makers-blog/465-how-to-turn-an-axc-f-2152-into-an-aws-greengrass-device.html
... the
balena build
command is used (in step 4) to create an image.What am I missing?
~ Martin.
I still had in mind that the build tools are not available with Balena. Either I'm confusing things or something has changed.
Right now I'm confused in my head
Then of course Balena works too.
G Jan
