.NET Core on PLCnext Control 2152
Hi, I found this description below in the PLCnext community but I have some trouble to get this run.
If I insert the command 'dotnet --info' then it seems that my setup is not correct. Result 'command not found'
How to use the .Net Core on a PLCnext Control
If you're a C# programmer working with a PLCnext Control then you might want to use the Microsoft® .NET Core runtime. Here's how to install it on an AXC F 2152 control.
Set up the runtime on the PLC
  1. Download the Dotnetcore Runtime Binaries - Microsoft .NET Core download site - for the AXC F 2152 it is Linux ARM 32bitNote: You may also use a newer version, e.g. 3.0
  2. Unzip the Runtime .zip file
  3. Unzip the Data folder
  4. Copy the unzipped files (host, shared and dotnet binary) to the controller at /opt/DotnetRT
  5. Create a symlink to the binary (as root user) ln -s /opt/DotnetRT/dotnet /usr/local/bin/dotnet
  6. Check if the link is setup correctly: lrwxrwxrwx 1 admin plcnext 20 Nov 27 12:50 dotnet -> /opt/DotnetRT/dotnet
  7. Check if installation was succesfull: dotnet --info
Do you have an idea, what I need to do?
Thanks.
Alex
  • Hi Alex,
    Is there an executable named dotnet in the directory /opt/DotnetRT/ ?
    Does this have execute privileges?
    What happens when you run the command /opt/DotnetRT/dotnet --info ?
    Is there a symbolic link named dotnet in the directory /usr/local/bin/ ?
    Is this symbolic link pointing to the dotnet executable in the directory /opt/DotnetRT/ ?
    Hopefully one of these checks will reveal the problem.
    Regards,
    Martin.
  • Hi Martin, I found a second example
    https://www.plcnext-community.net/en/hn-makers-blog/424-install-the-net-core-runtime-3-0-0-on-the-axc-f-2152.html
    This works also not exactly as described. I had some challenges to expand the files and copy to the PLC folders.
    After some loops I got it running,
    Putty:
    admin@axcf2152:~$ dotnet --info
    It was not possible to find any installed .NET Core SDKs
    Did you mean to run .NET Core SDK commands? Install a .NET Core SDK from:
    https://aka.ms/dotnet-download
    Host (useful for support):
    Version: 3.0.0
    Commit: 95a0a61858
    .NET Core SDKs installed:
    No SDKs were found.
    .NET Core runtimes installed:
    Microsoft.NETCore.App 3.0.0 [/opt/dotnet-runtime-3.0.0-linux-arm/shared/Microsoft.NETCore.App]
    To install additional .NET Core runtimes or SDKs:
    Now I will check, if I can work with TCPIP Socket (c#) on my PLCnext device ;)
    Thanks a lot.
    Alex
  • Hello Alex,
    the thing with Linux File Systems is that they are not supported by Windows so the moment you unzip it on a Windows OS lots of Linux file information go missing.
    like the permissions , Exectuion property or Symlinks.
    So after copying you need to restore those or unzip directly on the PLC.
    chmod +x File -> to make it executeabled.
    ln -s to restore symlinks...
    You do not need the SDK on the PLC.
    It also takes way to long to compile on target.
    For running code the runtime is enough...
    So I recommend you downloading the sdk to your PC only and set in the project properties that you are building for Arm32 Bit.
    kind regards,
    Oliver Warneke
  • My c# TCPClient is running on PLCnext controller, now.
    Thanks a lot and Merry Christmas.
    Alex
