Problems updating to FW2021.0
Hello.
I was working with an AXC F 2152 with FW2020.6 and Smart Elements and PLCnext Engineer 2020.6.2.
I updated to the new soft 2021.0.1 and FW 2021.0.0 LTS in the AXC
Then the AXC goes to FAIL (red led lights fix) and the soft gives me the error I send to you.
If I come back to the former version of FW2020.6, everything goes well with software 2021.0.0 LTS
Do you have news about a similar problem with the firmware update ?
Thanks for your help.
Best regards.
Julian.
Hi Julian,
I have seen the same issue yesterday.
The running project was with FW 2020.6 and Engineer version 2020.6.1 no problems there. Well, accept the slow VPN communication. What was the reason for the update.
I was running the FW update to version to FW 2021.LTS. After that I did a factory reset of the controller. In the time that went on, I did modify my project to the firmware template 2021.LTS.
Before downloading the project, I corrected the user admin in the WbM.
That all done, I downloaded the project to the controller. Well, got the same error as you did. Controller goes in to FAIL mode with no real information. Could not even get the logs from the controller.
So, I did restart the controller and now I have the D - LED on and nothing else. I can ping the controller but can't access anything. So I guess that I have now a new paperweight for my desk.
Since this is an running application at a client, my only option was to change the controller to a new one with FW 2020.6. Download my program and look - its running.
I know we are in difficult times and you guy's from Phoeninx are doing what you can. But this isn't helping us. You wish that we keep the firmware up-to-date, especially this version with the fix for the VPN communication. So please make sure that you don't kill our running applications.
This application has been running un-modified from firmware 2020.LTS and all in between up to FW 2020.6.
To end on a high note: I did have a controller in the office where I udated the FW to 2021.LTS for testing the VPN performance. There the update was going well. But there I have programmed the controller from scratch - a complete new project.
So Phoenix,let us know when you have come up with an explaination and a fix.
Peter Paul
Hi Julian, Peter,
first of all I hope that you've had pleasant start into the new year!
As second I've to apologize that you both ha directly issues during the update to the brand new 2021.0.
Of course we've spend a lot of time and effort to ensure that the firmware is compatible to the older versions, but as usual with such complex systems there might be gaps which we did not encounter.
It seem that you both found there a flaw!
Now it is for us most important to find the cause to help you and the community as soon as even possible.
I'm already in contact with Peter and @Julian I would come also directly back to you that we can have a closer look into your application as well.
I'll keep this post also for all the others open and will update it when there are some more details available.
Take care,
Frank
Dear All,
I faced with similar issue on fw2021. 0lst and 2021.0.1 engineer. After loading project to plc, it can't startup, and just D led on, with no any possibility to connect to device.
But in my case, before this issue occurs, I made some changes to Windows global settings for locales and encoding of charsets. Perhaps there is some troubles in engineering software attached to encoding of symbols in global Windows space. Best regards.
Dear all,
as we've found in the meantime the problem Julian had, I'd like to give you an update on this.
Maybe the solution would be also helpful for others.
PLCnext does use an overlay file system and all user modifications (maybe copy a file or complete project folders via WinSCP to /opt/plcnext/) will be stored in the /upperdir/.
The /upperdir/ will not be erased during a FW update as it contains user settings, like the project and maybe any other created file.
In this specific case were the complete /project/ folder copied into the /upperdir/ including the /default/ project which contains some general configurations.
Former FW versions (1.x and 2019.x) had also there the configurations from the internal tasks ServiceTask and Globals.
Those two files moved now in 2021.0 into the folder /etc/plcnext/device/PLC/ESM to simplify the general project structure.
However, during booting up the system did the PLC Manager found two configuration for one task and stopped the startup with an error.
To resolve the problem you can simply deleted both marked config files in the directory /media/rfs/rw/upperdir/opt/plcnext/projects/Default/Plc/Esm and reboot the device.
We apologise for the inconvenience and are already working on a general solution!
Have a great weekend,
Frank
