datalogger problem
Hello
I need help.
I downloaded DataLogger_V2 Library but when I insert DL_File_2 or DL_OnEvent_2 FB and I Rebuild I obtain two errors (see attached picture).
This appens even If I compile the example provided with the library.
I'm using PLC Next Engineer 2021.0
Many thanks
Claudio
Hey Claudio,
I've spoke with the creator of the app and with the PLCnext Engineer dev team.
With the Engineer version 2021.0 we've implemented a new compiler version which is unfortunately incompatible with one line of code inside the Datalogger lib.
However, we are aware of this issue and will offer in short time the following options for a fix:
With the umpcoming Hotfix will the compiler back compatible with the Datalogger_2_07.
The creator of the library planned anyhow a minor update and will implement now also a slightly change to be back compatible with Engineer 2021.0.
As soon as the new Datalogger Version is available, I'll update this post.
Sorry for the inconvenience and have a great weekend!
Frank
Thank you Frank
Best regards
Hi Claudio,
the new Datalogger Library (2.09) were now released and is available to download --> https://www.plcnextstore.com/#/919.
Next to some minor fixes and improvements it implements also a modification to be once again compatible to PLCnext Engineer 2021.0.
After replacing the library you should be once again able to compile and download the whole application.
Take care,
Frank
