RE: RE: Datalogger TSDB
Hello Martin,
I'm not sure why, but the chart is visible.
Is there a way to change the range of the axis?
Arne
Hello Martin,
Arne
Hi Arne,
I hope it's OK that I've branched this (again) into a separate ticket, since it is a different problem to the one described in the previous question.
The Chart object - which was introduced in the latest version of PLCnext Engineer (2021.0) has basic features that will be added to in future releases. If you can't set the ranges on the axes at the moment, then this feature will appear at some point in the future.
~ Martin.
