Connecting 1 OUTPORT to Many INPORTS
edited January 2021 in PLCnext Engineer
I want to work with several program's on  1 controller. 1 program is a kind of overal runtime handler which handles, for example, the reset handling.
I want to push the resetsignal, detected in the runtime handler to all other program;s.  Working with a global variable is not possible because the
scope from a variable can not reach beyond the runtime.
So i want to make the resetsignal an OUTPORT for the runtime program and INPORT for all other program's.. Is this possible? And how?
Thanks,
Marco van Os
GeoComfort
  • Hello,
    You can duplicate the OUT port using the context menu in the PLCnext Engineer "Port List":
    2021 01 29 10 54 38
    ... then you can connect the duplicated OUT port to another IN port.
    Hope this helps.
    ~ Martin.
