EngineeringLibraryBuilder.dll does not exist, visual studio c++
I'm having a lot of trouble with the C++ extension for Visual Studio. I followed the steps from https://www.plcnext.help/te/Programming/Cpp/Cpp_programming/Required_Installations.htm to install it for Visual Studio. And combine it with this tutorial for creating a simple project https://www.plcnext.help/te/Programming/Cpp/Cpp_programming/Creating_a_Cpp_project_in_Visual_Studio.htm
When I try to build a project (even a newly generated one)I get the error:
Error [EngineeringLibraryBuilder]: The application to execute does not exist: 'C:\Users\henne\AppData\Local\Temp\.net\EngineeringLibraryBuilder\ytgfomfx.llq\EngineeringLibraryBuilder.dll'.
I've been trying to fix this for some time now, but can't get it to work. Anyone knows how to fix this?
Regards,
Henne
Regards,
Henne
There is a similar issue described here:
https://www.plcnext-community.net/en/discussions-2-offcanvas/caching-error-during-project-startup.html
In that case, deleting the directory below the Temp directory was the recommended solution, so perhaps deleting this directory (or moving it somewhere safe!) will solve the problem.
~ Martin
