Alternative way to change IP address without PLCNext Engineer
One easy question, I hope. By problems with my firewall (company policies, etc), I can not find PLC Next PLC by Online Controllers. I can connect with PLC but not appears on Online controllers. I would like to change IP address to PLC but no way to do it because it doesn't appears on Online Controllers on PLCNext Engineer.
Is there an alternative way to do this?
Thanks in advance
Thanks in advance
Yes, if you can establish a secure shell session to the PLC, then you can edit the file /etc/network/interfaces (as root user) to change the IP address. Restart the controller afterwards to pick up the changes.
Hope this helps.
~ Martin.
