CPP: Keep alive of TCP server socket is not working
I'm using a PLCnect control as TCP server. The programming is done in C++.
The TCP server works fine and accepts a connection from my Windows PC. I implement the socket with enabled Keep Alive signal.
But when I disconnect my PC the connection is not terminated on the PLC.
When I use the IEC61535 Function Blocks the connection is also disconnected on the PLC and I can reconnect.
Can you help my to implement the same behavior in C++?
  • Hello pynl02,
    please see the attached cpp code, I think it will help you.
    If you have additionally questions, please contact me directly.
    Thanks & Best Regards
    Eduard
