CANOpen
This may be a dumb question but here is my situation, I have two PLCs that is connected in the same CANbus and I want to use the CANOpen protocol. I just want to know if I need an EDS file for the other PLC or is it only required if I use a bus coupler which is IL CAN BK-TC-PAC (2718701) ?
Thanks
  • Also, how do I set a node id to the PLC?
  • Hi izenreal,
    I'm sorry to say that nether on the PLCnext team is a real CAN expert, so we've to pass your question to one of our experts.
    Could you please describte a bit more in detail which kind of CAN moldue you are using and how your configuration should be?
    To give you a fast reply it would be great if you could add as much information as possible.
    Thx,
    Frank
  • Hello,
    I am using two AXC F 2152 (2404267) and two AXL F IF CAN 1H (2702668). Also, I am using CANbus_10 library.
    I really am beginner here and I am not sure if I am asking the right questions but this is regarding CANOpen protocol, I would like to know how am I going to set a node id to the PLC so that I can have my COB-ID. Do I need to use a software to configure these kind of things?
    Thanks
  • Hi izenreal,
    thanks for the details.
    I've spoke with our specialists and the AXL F IF CAN 1H with the used library is extremly flexible, but there is defenetly experience needed.
    This goes far bejond the possibilities of this forum and I strongly suggest to go in the direct contact with your local Phoenix Contact technical support.
    If you need a contact please let me know (fwalde@phoenixcontact.com).
    BR,
    Frank
