Problem with upgrade the firmware, boot led is blinking
Hello;
I try to upgrade the firmware of AXCF 2152 from 2020.0.1 to latest one. I received error during this upgrade.
Now I cannot even ping the PLCNext, the boot led is blinking.
How I can solve this problem?
Thank you
  • Hello Tanraneh,
    did you recieve any errorcodes?
    Did you power down the PLC after/during the update?
    Are you using an SD Card?
    First of all please try a Type 1 Reset.
    Give the PLC enough time to restore the defaults.
    If the PLC is still not reachable via 192.168.1.10 please try a Type 2 Reset.
    And again give the PLC enough time to restore the defaults.
    This one might take some minutes.
    Is the boot led blinking steady or is it inregular?
    kind regards,
