Program Phoenix AXC1050 via Tia portal.
I saw a video on Youtube where a phoenix was programmed in TIA portal. Is this also possible for the AXC1050 and which GSD-Files do I need to do this?
Besides that I would also like to communicate between the phoenix AXC1050 and a siemens PLC using OPC UA protocol, what is the best way to do this?
The name of the Youtube video is: “How to set up an Axioline F Profinet I/O station in the TIA Portal.”
I want to make a connection from:
Machine <----> Phoenix AXC1050 <----> Sierra RV50 Modem <----> Server <----> Tia portal WinCC.
So I thought that it would be nice if I could also program the phoenix in TIA portal.
I hope to have a reaction soon.
Thank's in advance!
Kind regards.
Thank's in advance!
Kind regards.
Firstly, I am afraid that the AXC 1050 is not a PLCnext Control device, and so is not part of the PLCnext Technology ecosystem, which is the exclusive subject of this forum. You can get technical support for all other Phoenix Contact products - including the AXC 1050 PLC - from the local Phoenix Contact office in your country.
In saying that, I may be able to offer some advice in this case:
I assume this is the video you mean ...
... and that yours is the comment below that video. :-)
That video explains how to connect a Profinet I/O station from Phoenix Contact to a Siemens PLC in TIA Portal. The Profinet bus coupler in that video is not a PLC. The use of TIA portal assumes a Siemens PLC, even though the Profinet I/O station is from Phoenix Contact.
If you want to treat the AXC 1050 PLC as a Profinet device, then - unlike the Bus Coupler shown in the video - you will need to program it using PC WORX 6 software. Then, there is a GSDML file for this PLC in the "Downloads" tab of the product page on our website:
https://phoenixcontact.com/product/2700988
If you need more help getting this working, please get in touch with your local Phoenix Contact office.
