REST API communication - Nginx / CORS
I ran into a problem with CORS blocking HTTP requests. By default, CORS is disabled in Nginx.
On https://ubiq.co/tech-blog/enable-cors-nginx/, I read that CORS should be enabled by adding:
add_header Access-Control-Allow-Origin *;
This allows cross-domain requests in Nginx, across all websites.
I attach the nginx.conf file and the screen from the Chrome browser console, where I have a test page made.
Adding a header in nginx.conf did not help and I still get the error. After installing the "Allow CORS" plug-in to the browser, the requests are carried out correctly.
Is the error on the side of a misconfigured nginx file, or is the browser itself blocking the CORS request from being sent?
I am probably not the first to encounter this problem.
Regards,
Kacper
[attachment]nginx.jpg[/attachment][attachment]chrome.jpg[/attachment]
  • Hi, sorry for the delay.
    I'm not sure if you have seen this recent post which also dealt with the topic of CORS:
    https://www.plcnext-community.net/en/discussions-2-offcanvas/front-end-use-of-the-rest-api.html
    Does the resolution described in that thread help in your case?
  • Hi,
    Thanks for submitting the post. I also made changes to the nginx.conf and nginx_ehmi_location.conf files. These changes did not help.
    I cannot locate the SSL.conf file on the driver.
    I am wondering about the influence of the SSL certificate on the solution of the CORS problem. How does uploading an SSL certificate eliminate the problem?
    Regards,
    Kacper
  • Hi,
    The problem has been resolved. I had to reconfigure the nginx.conf and nginx_ehmi_location.conf files according to what was presented in the posted post. In my case, no configuration with SSL certificates was required.
    Regards,
    Kacper
