MQTT Sparkplug B support on PLCnext
2»
  • Damian,
    I received your request and replied. I look forward to our discussion!
    Jake
  • Hi jake,
    I during the reinstall it skipped through the download quickly so i installed the gateway from another machine in case it cached the install file but it still has the same bug.
    Direct contact would be great! I'm just not sure how to message you directly?
  • I know that Jake is having trouble with notifications from this Forum (which appears to be the fault of the Forum, not Jake), so any technical support questions can also be sent using the method that Jake mentioned earlier in this thread:
  • OK so one more update on the current issue. I confirmed that all types work to be written to, it's just that if there are more than one tags in the Sparkplug system and a write comes from outside, the error occurs!
    I will get working on this fix. In the meantime, I will add a note on the current FW notes in the GW.
  • Small update. Corrected the errors described above. Running testing through the night and may have a build by morning. Will keep everyone posted 😀
  • edited April 2024
    Hello community,
    What are the brokers tested? thanks
    You can create a table with supported brokers like:
    Broker name | Version | Licensing | Test Result
    RabbitMq | 3.13.0 | Free & OSS | Pass/not Pass
    HiveMq | 2024.3 | Free & OSS | Pass/not Pass
    HiveMq | 2024.3 Prof | Paid | Pass/not Pass
    thanks!
