Python version on ipkg is 3.7.1, PyPlcnextRsc needs at least 3.7.6
Hi everybody !
I would like to use PyPlcnextRsc library on a AXF2152.
I would like to use a Docker to facilitate the deployment of my Python application.
I use IPKG manager as recommended by Phoenix.
(How to install the Optware Package Manager on a PLCnext Control | PLCnext Community Makers)
But with IPKG, the lastest version of python3 is the 3.7.1.
How can I do ?
Best regards,
François
How can I do ?
Best regards,
François
Firmware version 2022.0.3 includes python version 3.8.11
Okay if i was working on the PLC directly.
In my case, I would like to use a docker for some reasons (for example, deploy on Windows servers and multiple PLC in further steps).
The DockerFile I have created :
FROM bash
RUN wget -O - http://ipkg.nslu2-linux.org/optware-ng/bootstrap/buildroot-armeabihf-bootstrap.sh | sh
RUN export PATH=$PATH:/opt/bin:/opt/sbin
RUN /opt/bin/ipkg install python3
RUN /opt/bin/ipkg install py3-pip
RUN /opt/bin/pip3 install websockets
RUN /opt/bin/pip3 install asyncio
RUN /opt/bin/pip3 install jsonschema
RUN /opt/bin/pip3 install mysql-connector
ADD main.py .
EXPOSE 4444/tcp
CMD [ "/opt/bin/python3", "./main.py" ]
In this docker, I would like to add PyPlcnextRsc.
I tried to create my DockerFile from a Python3.8 image, but in this case, it was impossible to install other libraries with ipkg.
All images with Python3.8 I found was using apt-get.
For mysql-connector library, I was forced to do an apt-get update and that command was rejected by the PLC (EOF error)
Thanks in advance !
Perhaps the image is too big for the device.
Are you using a removeable SD card?
I have tried again with another base image and with apk package manager and it seems working.
For information, my DockerFile :
FROM alpine
RUN apk add --no-cache python3
RUN apk add --update py3-pip
RUN pip3 install mysql-connector
RUN pip3 install websockets
RUN pip3 install jsonschema
RUN pip3 install asyncio
RUN pip3 install -U PyPlcnextRsc
ADD main.py .
EXPOSE 4444/tcp
CMD [ "python3", "./main.py" ]
Thanks for your support.
