Programming a physical Momentary switch to be a maintained one.
How would one program a momentary button switch to be a maintained one with ladder logic. I have experimented with the different coil types to no avail. Some help would be greatly appreciated
  • I'm not sure if this is what you're looking for, but if you want to maintain the signal until a reset signal is received, you can use a latching relay - either an RS or SR function block.
    You could implement the functionality of these FBs yourself, but it is probably easier to use the FBs.
  • Cheers Martin, exactly what I'm looking for.
