MySQL connection C# library
Hello all,
Is it possible to use mysql.data package in c# in a PLCNext library. The newest versions require higher framework, but I am able to install MySql.Data Nuget Package version 6.9.12 in my project, since the package has no dependencies. But then I am not able to add "using Mysql.Data". Is this due to the PlcNext CLI? Is it somehow possible to use it? Or maybe in C++ then?
I am using the DBFL_SQL_5 right now in a .st file in plcnext engineer, but the handling of data is a bit complex since all data should be converted into strings before writing, and the buffer is too small to read a full row of data. So I am reading out the row per column right now, which cost around fourty cycles to get all data... Maybe I am missing some ways to simplify it with the function blocks, but now it's a bit messy with al the CONCATs, TO_STRINGs and multiple different read commands + write to one db, and a write to a different one.
So should I just take the 'messy' ST solution, or is it quite easy to use C# (or C++)?
Arne
I had to add the reference once more by hand, since it was not in the list of selectables, but now I am able to use it. will try to implement it now.
Seems like system.data is necessary, but that will retarget the project from eclr 3.3 to .net framework 4...
Same problem… Did you find any solutions?
