SFC Initialisation
I'm currently trying to do the following thing on the SFC add-on :
An emergency stop is activated, i set my SFC to HALT mode,
Then a button 'Reset' is push, the SFC come back to step 1.
I found how to set to HALT mode, but i can't find how to put the SFC to step 1.
How can i do ?
Here is the answer from the PLCnext Engineer support team:
if you set the variable to "Halt"-Mode you can operate via. the inputs
Step_ID and Activate_Step to the first step for example.
The right Step_ID can be select below the struct Step_States.
Important:
The ID can be different to the Step count.
Example = Step 1 has ID 2
If you have additional questions do not hesitate to ask.
Hi Robin02,
first things first so check the help page for programming in SFC. You'll find the FBs' parameter description.
Then I would suggest something along this pseudo code:
IF ResetButton = TRUE AND SfcFB.Active_Operating_Mode = HALT THEN
//Go through all steps and deactivate them
WHILE(I < Step_States.StateCount) DO
SfcFb.Deactivate_Step(Step_States.StateList[I]);
I++
End_while
//Crawl through the structure and check the object property. Return the ObjectID of init step
InitStepID := FindInitStep(SfcFb.STRUCTURE);
SfcFb.Activate_Step(InitStepID)
End_If
