PLCnext not booting when using SD card
Everytime I turn on the AXC F 2152 with an SD card (2GB; PxC), it stays with the boot led blinking and the D led on. I've tried to use the recovery command (both 1 and 2), but none of them work. I've also tried resetting the PLC using the physical button with no results.
If I boot the PLC without the SD card, it works just fine.
What could I do to fix this issue?
Thanks.
  • edited August 2022
  • Hello vcorona,
    what is the Firmware Version of your PLC?
    Please try updating the PLC before trying again.
    Also make sure the SD is writeable (lockswitch).
    kind regards,
  • Also just to check:
    Did you happen to insert the SD card into an external drive, perhaps on a Linux machine?
    There are files on a new SD card that, if deleted, will make the card unusable in PLCnext Control devices.
    The PLC is currently at HW: 02 FW: 2022.6.0.
    I haven't added or deleted anything on the SD whatsoever. The SD just stopped working after a boot, before that it was working fine.
    Thanks.
