EPC1502 - Add Telegraf Plugins
I am trying to use the MySQL Telegraf Plugin to get data for InfluxDB. When I create a new Telegraf Configuration there are just a few options to use
How can I use different Plugins? Is it possible, or it is not allowed in the current FW revision (2022.0.7 LTS)?
Thanks a lot and best regards,
Alvaro
Hello Alvaro,
I am really sorry you haven't received a earlier answer.
I've tried my best, but have no experience in the MySQL Telegraf Plugin.
In general, Telegraf plugins are a bit complex to esablish.
I have documented an example where I installed the "Network Interface Performance" Monitoring via a Telegraf Template:
EdgeDevices/Templates.md at main · PLCnext/EdgeDevices (github.com)
All other InfluxDB Templates should be installed quite the same.
It might be worth a try, asking deep-dive InfluxDB question inside the InfluxDB Open-Source forum as well.
Let me know, if that example helped you.
Best regards,
Daniel
