Converting String to Bits
Hallo,
I´m having a hard time programming with the PCWorx Engineer.
There are a lot of basic FunctionBlocks/Functions meantioned in the help center and/or selectable in the programming interface, which are not implemented for the PLCnext.
Examples:
WORD_TO_BITS
When I type this in ST-Code there is a quick help (showing the function arguments order) for it but it is not working.
PULSE_GEN
German error msg:
"Die ausgewählte Ressource axcf2152:OLC unterstützt die Programmorganisationseinheit ACTF nicht"
"Die ausgewählte Ressource axcf2152:OLC unterstützt die Programmorganisationseinheit PULSE_GEN nicht"
I could add more examples...
Could you help me to find an efficient way to convert a String containing a HEX number to Bits?
The String could look like this "input;00C3" and I need to split this into Bits.
Converting the String into a Number always converts it from DEZ to whatever. I don´t know how to Handle it as HEX Numbers.
My Workarround in ST is not really efficient:
/*parse string: input:0000KOMISCHESZEICHEN*/
//cut number from String
str_tmp:= str_in;
str_tmp:= DELETE(str_tmp,6,1);
//number String to Buf (takes number as DEZ but is really HEX)
b_cpyRdy:= STRING_COPY(str_tmp,buf_tmp,0,4);
r_tmp:= 0;
//reconvert false DEZ to real DEZ
(* Variable und alle Werte müssen vom Typ INT sein *)
FOR int_i := 0 TO 4 BY 1 DO
int_x:= int_x+1;
CASE TO_INT(buf_tmp[int_i])(* Ausdruck (muss einen INT Wert zurückgeben*) OF
48: ;//0 -> muss nicht berechnet werden!
49: r_tmp := r_tmp + 1*EXPT(anyreal16,3-int_i);//1
50: r_tmp := r_tmp + 2*EXPT(anyreal16,3-int_i);//2
51: r_tmp := r_tmp + 3*EXPT(anyreal16,3-int_i);//3
52: r_tmp := r_tmp + 4*EXPT(anyreal16,3-int_i);//4
53: r_tmp := r_tmp + 5*EXPT(anyreal16,3-int_i);//5
54: r_tmp := r_tmp + 6*EXPT(anyreal16,3-int_i);//6
55: r_tmp := r_tmp + 7*EXPT(anyreal16,3-int_i);//7
56: r_tmp := r_tmp + 8*EXPT(anyreal16,3-int_i);//8
57: r_tmp := r_tmp + 9*EXPT(anyreal16,3-int_i);//9
65: r_tmp := r_tmp + 10*EXPT(anyreal16,3-int_i);//A
66: r_tmp := r_tmp + 11*EXPT(anyreal16,3-int_i);//B
67: r_tmp := r_tmp + 12*EXPT(anyreal16,3-int_i);//C
68: r_tmp := r_tmp + 13*EXPT(anyreal16,3-int_i);//D
69: r_tmp := r_tmp + 14*EXPT(anyreal16,3-int_i);//E
70: r_tmp := r_tmp + 15*EXPT(anyreal16,3-int_i);//F
//usw A,B,C...F
END_CASE
END_FOR
int_x:= TO_INT(r_tmp);
w_out:= TO_WORD(int_x);
Thanks for your help,
Jimmy Pesto
Hello Jummy,
If you can tell me the version of PC Worx Engineer you are using, I can look into this further. The next version of software (now called PLCnext Engineer) should be available in the coming weeks, and I hope that you will not have the same issues with the new version.
For the string conversion, I suggest the following:
Note that you can use different prefixes and conversion functions, depending on the number of hexadecimal digits you need to convert at once.
You can then refer to the individual bits in the BYTE, WORD etc. using dot notation - e.g. MyVar.X0 to refer to bit 0 in the variable MyVar.
Hope this helps.
- Martin.
Hey Martin,
thanks for your quick response.
I´m currently using PC Worx Engineer 7.2.2.
Nice, I wasn´t aware of the possibility to specify the number system within the string. It works like acharm.
Is there also a way to set Bits in a Word more efficiently then in my solution?
w_out:= w_out AND NOT SHL(bitOne,n_0);
w_out:= w_out OR SHL(b_0,n_0);
w_out:= w_out AND NOT SHL(bitOne,n_1);
w_out:= w_out OR SHL(b_1,n_1);
This helped a lot, greetings,
Jimmy
Hi Jimmy,
Re. software version: You can download a later version (7.2.3) from our website, maybe give this a try and see if the problems remain? If so, perhaps you can send a small project showing the problem(s).
Re. setting bits in a word: You can do this a few ways:
1. Use dot notation, so to set the first (least significant) bit in a word:
w_out.X0 := TRUE;
With this notation, you can't use a variable to specify the bit number.2. Use the "bit manipulation functions" - e.g. GET_BIT(), SET_BIT(), RESET_BIT(), INVERT_BIT(). Using these functions, you can use a variable to specify the bit number.
Hope this helps.
- Martin.
