Reading CPU Temperature from Linux
Has anyone found a temperature on the device that relates directly to CPU Temperature?  I have a customer with this requirement at the moment.
I have found a temperature from a humidity sensor at:
/sys/class/hwmon/hwmon0/temp1_input
but I am not sure where this temperature is taken.
Any ideas or help would be greatly appreciated.
Thanks,
Steve
  • Hi Steve,
    I'll check this and come back to you asap.
    cheers
    Frank
  • Hi Steve,
    I've news for you. We've a humidity sensor mounted directly left below the heat sink.
    The temperature can be read with /sys/class/hwmon/hwmon0/temp1_input.
    Means we are measure the temperature of the housing not of the CPU (there is no sensor installed)
    take care!
  • HI Frank.
     I have edited the tempertaura and humidity file and the value that appears is 47445 What value will be refere? 47.445ºC and that of humidity puts 10906
  • Hi rcasadomozo,
    you can look in the following link for exact information about the contents of the files.
    https://www.kernel.org/doc/Documentation/hwmon/sysfs-interface
    The temperature should be in millidegree Celsius, as you described. The humidity should be indicated in milli-percent.
  • Hi
    Can you tell me how to make a variable for it on the AXC F 1152 controller so I can show it on the webhmi?
    I need the temp in the housing. If it not possible I can maybe use the CPU temperature but thats not a proper solution.
  • Hello,
    For the temperature sensor discussed in this thread, there is a system variable available, here:
    2020 04 12 14 19 47
    If you need help displaying this on the HMI, please create a new question in the "PLCnext Engineer" category, and someone will answer it there.
    ~ Martin.
