PCWorx adaptation library: where is it?
Hello experts,
When I import a PLCOpen XML file from a PCWorx program, I get a list of "MSG"-s, which tell me about the code that must be replaced. One of the messages says:
"Warning","14/03/2023 11:49:26","PLCopen XML Import","MSG_PRG0065","The conversions BYTE_TO_*INT, BOOL_TO_*INT and **WORD_TO_*INT (where ** stands for ""D"", ""L"" or """" and * stands for ""D"",""S"", ""L"",""UD"", ""U"", ""UL"",""US"" or """") of MULTIPROG 5.x/PCWORX 6.x are not 61131-3 3rd edition compliant and have been moved from the default to a separate adaption library of PLCnext Engineer. Please consider using the 61131-3 3rd ed. compliant POUs TO_INT/DINT/LINT: Instead of honoring the sign bit just the rightmost bytes will be copied now."
I understand that it is possible to replace said functions with IEC compliant ones, but the message also clearly states that there is a 'separate adaptation library'. Where can I find that?
@Martin PLCnext Team : in another thread you offered to send the complete list of 'things to replace' to another user. Could you please also send that to me? Thanks!
