HMI Symbol TAG nested
I'm using PLCnext Engineer 2023.0 and I'm trying to instantiate several times a symbol inside another symbol. The first symbol has an HMI tag to evaluate the inputa data before pass it to a variable. The problem starts when I instantite this symbol several times for different parameters but the HMI tag seems the same for every instance.
First symbol:
Symbol instantiatied several times:
The result is when I try to change one parameter, every instance changes their Tag:
In addition the faiure of the DropList object which always stays behind other objects, despite you configure it above:
I appreciate your help.
Juan.
