Proficloud Graph Units
Hi, I made a graph with 4 viariables. I need to compare them. I want to know if it is posible to have on the same graph difrent Y Axes with diferent units.
I try to used the Y left and the Y rigth but nothing happend on the graph.
Thanks, Lucas
Hi Lucas,
you can configure two different y-axes in a panel and you can set scaling, units etc for each of the axes.
You found this already as shown in your screenshot.
You can click on the colored indicator next to the series within the legend of your panel and customize the settings for that particular item.
To assign a signal to the second y-axis, select the "Use right y-axis"-button.
Best regards,
Alexander
