Factory IO connecting issue OPC
I used the video https://youtu.be/cTAbPPl6vIU to try to connect my Controller to Factory IO and at the end I got the following error on the Factory IO
OPC Client DA/UA
The chosen security policy is not supported by the client to connect to the server
What do I need to do to make it work ?
Thank you
  • This sounds like an issue with the Factory IO configuration.
    In case he doesn't see this question, you could try asking the developer e.g. in the comments section under his YouTube video.
