Problem developing ACF C++ application
I am trying to set up a C++ application that can access the PLCnext GDS through RSC. I figured I need an ACF application to do this (Is that correct?).
However, when I try creating an ACF project from template in Visual Studio 2019 the default project shows errors right away. This happens for PLCnext C++ SDK versions 2021.6, 2022.0 and 2022.6. Depending on which 'platform toolset' I select in the Properties window (GCC for Windows Subsystem for Linux or GCC for Remote linux) there are different errors. Especially the WSL one gives a lot of very specific syntax errors in multiple dependency files (over 200 errors). Sounds like a versioning problem to me, but I have no clue where to start solving this problem.
I'm running Windows 11, developing for AXC F 2152, PLCnext toolchain version 2022.0.
Any suggestions/solutions are appreciated, thank you in advance!
Bart
