Internet Connection for plc next
The issue I'm facing pertains to establishing an internet connection. I've been attempting to connect using both Wi-Fi and Ethernet through a switch. Additionally, when following a specific guide to connect through Putty, the Putty application unexpectedly shuts down. Despite attempting various IP addresses within the same network, the problem persists. I'm utilizing PLCnext Engineer 2023.3 for this task and have conducted scans using tools like nmap and Wireshark to confirm the accuracy of the IP address. Despite confirming the correctness of the IP, I'm unable to establish a successful connection using Putty. time is also synchronized I am trying to connect to Profi Cloud Services and to PLCnext Store there was a connection before and now there is no connection I tried to set all options to the factory version I have a test version of kit but i still have problems
https://www.plcnext-community.net/makersblog/setting-up-an-internet-connection-axc-f-2152/
Can I ask for a video tutorial on how to set it all up?
I'm not a fan of the makers blog you reference - it seems to be more complicated than is necessary, maybe because the author did not have the freedom to configure his local ethernet network as he wanted, and so needed to find some work-arounds to, for example, find a free IP address on his LAN.
The process for connecting a PLCnext Control device to the Internet is the same as for any other Ethernet-based device. Since every user's LAN could be different, there's not really one procedure that suits all applications.
If you can provide a diagram showing:
... then that will help to understand what the problem is.
Or, if you can at least answer these questions, that will help to identify the issue:
ok i sort to connection you need start putty as administrator but still i cant have confection with Profi Cloud Services
You can ignore Proficloud for the moment.
You should be able to use PuTTY to open an SSH connection to the PLCnext Control device, using:
Then, you should be able to answer the five questions I listed.
I have no problems connecting to the internet anymore I have a problem connecting to https://app.proficloud.io/ I'm trying to add a certificate but I get an error
OK, this is a different issue.
If the information in the Proficloud Knowledge Hub does not help, please contact the Proficloud support team using the form on their website:
They will be able to give you personal support to help you set up your Proficloud connection.
Connection attempt failed. MQTT error. i think i got problem with UUID
Martin Could you deleted my post with UUID number please
