Node Red por PlcNext port 51880 not working
Hi
I did install the Node Red for PlcNext App ver 3.0.2 for a AXC F 2152 Ver 2023.6.0 (23.6.0.43) and is running.
When I try to access https://localhost:51880 id does not deployed the node red.
I set my PC and browser with all the permissions.
Any suggestions?
  • I might be misunderstanding the question, but if you have a service running on an AXC F 2152, then you cannot access that service from a PC using "localhost" on the PC, because that refers to the PC itself. You will need to use the IP address (or DNS name) of the device that is running the service (i.e. the AXC F 2152).
    You could also try contacting the developer of that app using the "Contact Developer" button on the app page in the PLCnext Store.
  • Hi
    To be more clear I´m using the ip adress of the AXC F 2152, https://192.168.1.10:51880, but it does not work.
  • in my case I had to do a factory reset because I already had node red installed and sometimes you have to wait a very long time for node red to load from the plcnext store
    I don't know why but node red in plcnext is terribly buggy but installed in balena it works very well but it would be useful to have instructions on how to do it via docker opc server works very well but uaexpert now does not show changing tags but it works and changes what I want
    insturction how to install on belena
    https://www.plcnext-community.net/makersblog/node-red-and-getting-started-with-docker/
