PC Worx Engineer Eclipse Plugin Error logs
For a (yet) unknown reason, the EngineeringLibraryBuilder stop working properly.
It started with a java exception warning window (with no references to Phoenix Contact components), and the following times, no feedback at all. Then I realized the same thing happened for "Insert Program Ports" and "Generate .progmeta Metaconfig " plugin utilities.
Recreating a new C++ PC Worx project from scratch and copying all original C++ source code in it seem to fix the problem, but as soon a new mistake occurs (like an error in a meta data files), the problem starts again.
So it look like some corruption that occurs in the project configuration.
==> Few days ago, I started to create output ports with larger arrays (1000 basic type items). Could it be the source of the problem ?
==> Is there a way to find hints of the problem by some method or hidden log files ? It would be precious to get the console output of EngineeringLibraryBuilder.exe
I am also starting to wonder if there is any compatibility issues I must be aware of ? For example:
- 32 bits vs 64 bits (I installed everything using 64 bits packages when the choice was offered) ?
- Eclipse version (I am using the Oxygen v4.7.3a, installed on a path without spaces) ?
- java version ( under C:\Program Files\Java\jre1.8.0_201 ) ?
- Compiler optimization or debug level ?
My system configuration:
- PC Worx Engineer v7.2.3
- Toolchain v2.2.1
- com.phoenixcontact.cdt.updatesite_build_1.0.0.201711221106
- EngineeringLibraryBuilder v1.3.0.0
Thanks for any help.
as far as I see from your other posts, you switched to the firmware 2.0 and the associated development environment. This should have solve the problems.
I still need to deliver my current work soon using the previous framework. Switching port definition framework is risky at this point, and the updated English documentation is not yet available.
REPORT
comment
eclipseBuildId 4.7.3.M20180330-0640
eclipseProduct org.eclipse.epp.package.cpp.product
javaRuntimeVersion 1.8.0_201-b09
osgiWs win32
osgiOs Windows10
osgiOsVersion 10.0.0
osgiArch x86_64
severity UNKNOWN
STATUS
pluginVersion 3.109.0.v20170411-1742
code 0
severity 4
message Unhandled event loop exception
fingerprint d7b834750ef701ba3c6103141b29e8f8
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:305)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:239)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:431)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:446)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:472)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(null:-2)
at sun.reflect.NativeMethodAccessorImpl.invoke(null:-1)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null:-1)
at java.lang.reflect.Method.invoke(null:-1)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Caused by: java.lang.NullPointerException: null
at HIDDEN.HIDDEN(HIDDEN:-1)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:577)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:291)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:92)
at sun.reflect.GeneratedMethodAccessor77.invoke(null:-1)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
BUNDLES
version 1.0.0.201711221106
version 3.9.0.v20170530-1048
version 1.6.100.v20170515-1119
version 3.13.0.v20170207-1030
version 0.12.100.v20170513-0428
version 1.6.0.v20170322-1144
version 1.6.100.v20170421-1418
version 1.5.1.v20170815-1446
version 0.14.102.v20180117-1153
version 0.14.101.v20170710-1119
version 1.3.400.v20150715-1528
version 1.4.0.v20161219-1356
version 3.13.2.v20171022-1656
version 3.106.3.v20180329-0507
version 3.109.0.v20170411-1742
version 1.2.0.v20170512-1452
version 3.13.1.v20170822-1526
Ok, with the stack trace it does not look like a defect in our Plug-in.
Never the less with a bit of searching on stack overflow, it looks like a known defect in a version of org.eclipse.ui.
https://stackoverflow.com/questions/9074189/unhandled-event-loop-exception-in-plugin-org-eclipse-ui
