Modbus TCP Communications
"I am sharing a Modbus TCP Client communication example that I applied in the field in the attached photo. I'm not sure if I am using the inputs such as 'tUpdateTime' and 'tReconnectDetail' correctly, as well as 'tTimeout'. Because when I specified a duration, I noticed that it did not work according to those durations.
My questions are as follows:
- What is the most accurate and optimal use of these blocks? What advice do you have for configuring them more optimally and effectively in the example I shared with you?
- How should I use the time-related inputs I mentioned above?
- What advice do you have regarding the use of FC23 blocks?
- Thank you for your answers. Have a great day!"
