OpcUA and user defined data (UDT) is it possible?
I have a remote siemens opc_ua_server with a UDT_TABLE looking like this:
The table is for a calender based start/stop function.
So i have declared them in siemens based on weekdays(Sunday through saturday):
But now my customer want to centralize this to a plc-next controller, so i begun doing some tests. And therefore I'm curious, am I limited to using the following variable identifier, that connects directly to the integer value (s="DB_TID"."MONDAG"."START_B_H_FM") or can i somehow connect it to a udt that is defined in the same way in plcNext? since this would mean either 98 separate variable mappings or 7...
And if I want to both write and read the tags, do I need to define them both as Group type Write AND Group type Subscribe?
BR
Mike
  • According to the Info Center:
    Since UDTs are structures, unfortunately it's not possible to link them directly to a single OPC UA Client variable.
    Yes, that's correct.
