Modbus RTU communication configuration in TIA portal (Siemens) using AXL SE RS 485 module
Hello!
In my present HW configuration I use S7-1500 PLC (TIA portal) with AXL SE RS 485 as Modbus RTU comunication modules.
I'm sure you have an example functions to configure communication via AXL SE RS 485 by Modbus RTU.
Could you please share a sample code ?
Standart Siemens function blocs not sutable for AXL SE RS 485 configuring...😔
Thanx in advance.
